13 years agoDDR3 Uniphy hang
Hi, I got issue with regards to running single write in sample project using DDR3 uniphy. I am using Cyclone V GT. The projects compiled ok, timing requirements are met, fully constrained(ref...
13 years agoif you run the EMI Toolkit, you'll get visibility into what specifically is causing the problem
you might also try and back off the frequency
