13 years agoDDR3 Uniphy hang
Hi, I got issue with regards to running single write in sample project using DDR3 uniphy. I am using Cyclone V GT. The projects compiled ok, timing requirements are met, fully constrained(ref...
13 years ago --- Quote Start --- did you take a look at the status signals as i mentioned? this will tell you if the calibration has passed --- Quote End --- Hi, I just try to monitor the afi_cal_success and it is always low. afi_cal_fail is always high.. seems like the calibration is not ok. What should be the cause of this? Any thing I should do?
