DDR3 timing errors on Cyclone V
Thanks for the attachment.
I've gone through it and below are my comments.
"The timing constraints for this core are broken."
I slightly disagree with this statement because of following reasons:
- The timing violation is occurs between the EMIF IP and other block designs as shown in the Report DDR. Therefore it's not in the core.
- ; Core (Slow 1100mV 85C Model) ; Slow 1100mV 85C Model ; -3.392 ; 0.173 ;
- I created a design containing EMIF IP and run through the flow and there is no violation.
- Might be not accurate so if you can provide a small toy design that can replicate the issue, that will be good.
Since this timing issue occurred between EMIF IP and user logic/module, not in the core, a normal timing closure method is applicable. e.g. add pipeline register or set max delay constraint.
- Seadog4 years ago
The timing violation is between the From Node and the To Node, by definition. Those nodes are:
From Node:
ddr3_v20:ddr3_v20_inst
>ddr3_v20_0002:ddr3_v20_inst
>ddr3_v20_s0:s0
>altera_mem_if_sequencer_cpu_cv_synth_cpu_inst:cpu_inst
>W_alu_result[9]~DUPLICATE
To Node:
>ddr3_v20_s0:s0
>sequencer_scc_mgr:sequencer_scc_mgr_inst
>scc_parallel
Launch Clock:
ddr3_v20_inst
>ddr3_v20_inst
>pll0
>pll6~PLL_OUTPUT_COUNTER
>divclk
Latch Clock:
ddr3_v20_inst
>ddr3_v20_inst
>pll0
>pll7~PLL_OUTPUT_COUNTER
>divclk
Both nodes (as well as the PLL which generates the launch and latch clocks) are instantiated within the hierarchy of the memory controller IP (core name is ddr3_v20). I didn't write any of that code.
