11 years agoDDR3 Memory errors but passes Calibration
Hi We are getting intermittent memory read errors from our DDR3 SDRAM Controller with UniPHY hmc in a Cyclone V Using the EMIF toolkit we can run calibration on the memory and it passes every time...
11 years ago --- Quote Start --- Hi thanks for reply. clock frequency is 300 MHz. Yes I will look with a scope but since the problem is only present after particular resets/calibrations I'd not thought of it as a possible cause of the problem. I will also try slowing down the clock as you suggest. Thanks Dave --- Quote End --- Hi I've slowed the clock down to 250MHz with no improvement. :(
