10 years agoDDR2 VREF problem
Hi, My FPGA design uses 4 ddr2 devices. And I use LP2996 to output VTT and VREF for FPGA and DDR2. However, VREF measures 1.43V other than 0.9V. After I cut the VREF output trace, I found LP299...
10 years agoI'm not sure either, but if you can lift a pin and add a jumper on the LP2996 you can run a quick test.
