16 years agoDDR2 SDRAM on Stratix III (DE3)
Hello, i have a DE3 board in which i want to includ the SDRAM. I created a Nios-uController and the DDR2 controller in the Megawizaard-plugin-manager. But how do i connect the IP-core with th...
16 years agoThe CD contains a DDR2 example in the DE3_demonstrations folder. Here are the connections to/from the NIOS given in verilog:
.clk(OSC1_50), .reset_n(system_reset_n), .in_port_to_the_pio_button(Button), .out_port_from_the_pio_led({LEDR, LEDG, LEDB}), .global_reset_n_to_the_altmemddr(system_reset_n), .local_init_done_from_the_altmemddr(), .local_refresh_ack_from_the_altmemddr(), .local_wdata_req_from_the_altmemddr(), .mem_addr_from_the_altmemddr(mem_addr[12:0]), .mem_ba_from_the_altmemddr(mem_ba[1:0]), .mem_cas_n_from_the_altmemddr(mem_cas_n), .mem_cke_from_the_altmemddr(mem_cke[0]), .mem_clk_n_to_and_from_the_altmemddr(mem_clk_n), .mem_clk_to_and_from_the_altmemddr(mem_clk), .mem_cs_n_from_the_altmemddr(mem_cs_n[0]), .mem_dm_from_the_altmemddr(mem_dm), .mem_dq_to_and_from_the_altmemddr(mem_dq), .mem_dqs_to_and_from_the_altmemddr(mem_dqs), .mem_dqsn_to_and_from_the_altmemddr(mem_dqsn), .mem_odt_from_the_altmemddr(mem_odt[0]), .mem_ras_n_from_the_altmemddr(mem_ras_n), .mem_we_n_from_the_altmemddr(mem_we_n), .oct_ctl_rs_value_to_the_altmemddr(), .oct_ctl_rt_value_to_the_altmemddr(), .reset_phy_clk_n_from_the_altmemddr(), .out_port_from_the_ddr2_i2c_scl(mem_SCL), .bidir_port_to_and_from_the_ddr2_i2c_sda(mem_SDA)
