18 years agoddr2 high performance ip core
i am designing PCI2DDR2 interface i want to use the ip core with CycIII device. does the core support ECC thats less then 64 bit? the PCI data is 32 bit i am going to interface 10 DDR2 compone...
18 years agoMost memory modules have already two ranks or blocks of memory internally, they have basically separate chip selects and ODT signals, also at least two pairs of clock signals. The memory controller is controlling ODT in an appropriate way. However, different techniques have been suggested by memory manufacturers regarding optimal ODT control. The weak point with Altera memory controller and Cyclone II/III or Arria/Stratix II is, that no dynamic on-chip-termination at the FPGA side is present. This feature is starting with Stratix III.
