19 years agoDDR2 Design with Cyclon III
Hi all I just started a new desing using a Cyclon III to interface discrete DDR2 memory (No DDR2 module!). It is just one single chip per interface. Can someone help me choosing the right...
18 years agoINteresting... I did the same and ended up putting series termination resistors and pull ups on address lines and control lines, I am using 200MHZ clock, trace less then 2", 3C16 Cyclone device and MT47H32M16 from Micron DDRAM II. Can you tell what rising/filing time you getting from your simulation??
