18 years agoDDR2 cyclone III FPGA dev kit
Hello, I would like buy the Cyclone III FPGA dev kit. I see that they are on the kit 5 case of DDR2 SDRAM. So I would like know if the code for read and write on the cases is include in the ki...
18 years agoIt seems that Quartus has trouble processing the timing constraints file for the DDR controller. I'm not sure what's wrong exactly, but you should definitely try with 7.2 and see if you have the same problem.
Do you have any messages between the "Reading SDC file: 'altmemddr_phy_timing.sdc'" line and the big error message on the top of your screenshot?
