14 years agoDDR SDRAM interface for EP3C10E144
Hi Folks, I am trying to work which pins I need to connect for DDR SDRAM on the 144pin version of the EP3C10 device. I am a little confused: I want to use a x16 memory device and so w...
14 years agoHello Again Socrates :-)
just to see what is required I generated the SDRAM controller in my CPU, and it still requires the use of DM bits (4 for a 32bit bus width). But now DQS is not required (obviously as it is no longer DDR). Did you mean SRAM and if so is there an SRAM controller core? Thanks for your help (once again!). D
