16 years agoDDR Output Constraining - "too positive" slack
Hi, I hope someone knows the solution to the problem that kept me really busy lately :( I have to connect to an RGMII PHY that has the following parameters: tCLK = 8 (ns) TskewR (Da...
16 years ago --- Quote Start --- 125MHz should work without a PLL... --- Quote End --- Are you sure? I made a small test and I couldn't meet timing. Note that per RGMII specs, the clock must be delayed and center aligned. To comply with the specs without a PLL (and without enabling the PHY clock delay), I had to insert a bunch of LCELLS before the clock output. Then I could meet timing at either the slow or fast model, but not at both. The main problem seems to be that the PVT variation of the LCELL delay-chain is too much. And the fact that he is using a Cyclone II without hardware DDIO support doesn't help. But it was a quick test, I might have missed something.
