16 years agoDDR Output Constraining - "too positive" slack
Hi, I hope someone knows the solution to the problem that kept me really busy lately :( I have to connect to an RGMII PHY that has the following parameters: tCLK = 8 (ns) TskewR (Da...
16 years ago --- Quote Start --- Thanks for the reference, I already read this several times :-D but as I said, PLLs are not an option. --- Quote End --- You are misunderstanding my point. The phy device can center-align the clock for you, at least most PHY have that capability. My point was that if you don't use a PLL to shift the clock, then you should enable the clock delay on the PHY. And that with none of them (no PLL shift in the FPGA, and no clock delay at the PHY), then meeting timing would be very difficult. Regarding your exact TimeQuest issue, I think you are missing the multicycle exception statement (Rysc would correctly if I'm wrong). But again, constraints would be completely different with or without the PHY clock delay.
