16 years agoDDR Output Constraining - "too positive" slack
Hi, I hope someone knows the solution to the problem that kept me really busy lately :( I have to connect to an RGMII PHY that has the following parameters: tCLK = 8 (ns) TskewR (Da...
16 years agodipling,
Check this: http://www.altera.com/literature/an/an477.pdf As mentioned on that note, most PHY devices have an option to center-align the clock. Without a PLL to shift the clock at the FPGA, it would be very difficult to meet timing otherwise. This is valid both for the transmitter side and the receiver side (as in your other post).
