16 years agoDDR input without DPA in Arria II GX
Hello I am using arria ii gx to communicate with a high speed device. The device is sending DDR data, data with a data clock, dclk. dclk and data are source synchronous. I need to capture the d...
16 years ago --- Quote Start --- Can I use "rx_dpll_enable" at run time to dynamcially enable/diable dpa circuitry? --- Quote End --- Unlike Arria I, Arria II GX hasn't a DPA bypass multiplexer. It can be configured either in non-DPA or DPA mode at compile time. As with Arria I, you can however freeze the current DPA phase by asserting rx_dpll_hold. This is necessary, when the DPA adjustment is done based on a train pattern, but the regular bitstream isn't guaranteed to have edges.
