DDIO Input Speed Cyclone V vs. Cyclone 10GX
Since I still couldn't open the project you provided, I created a project with cyclone 10gx device to match your netlist.
I wonder if the IP you used in C10 GX project is "GPIO Intel FPGA IP"?
I used this IP in cyclone 10gx project and found that it is true that the Fmax is under 200MHz.
When Fmax Restricted = Fmax, it generally means that the speed is limited to the design instead of device.
In this case, it might be related to the IP itself.
Thanks & Regards,
XY
Thank you for taking the time to re-create the project and to verify my result, that Fmax < 200Mhz. I used the "GPIO Intel FPGA IP" as you guessed. What I don't understand is why the cyclone 10gx is so much slower than the cyclone 10 lp, or even the cyclone v. I'm trying to design a 64 bit, DDR, source-synchronous deserializer with an input clock rate of at least 350Mhz. The DDR input speed is key to my design and I can't seem to achieve it with what is supposed to be a high perfomance FPGA.
