DDC Mixer Scale Block (https://www.intel.com/content/www/us/en/programmable/documentation/hco1423077212985.html#hco1423076748310)
- 7 years ago
Based on my understanding, Q18.1Std should be sufficient. You can find it under dspba -> Examples -> Platforms -> demo_ddc.mdl in DSP builder.
Sorry for the delay. As I understand it, you are looking for the "DSP Builder DDC Design Example" as discussed in the DSP Builder for Intel FPGAs (Advanced Blockset): Handbook. For your information, this is an DSP Builder example design but not a specific IP block. To use the example design, you would need to installed compatible Matlab version and DSP Builder software for your Quartus. Note that you would require separate licenses for Matlab and DSP Builder softwares. After you installed DSP Builder, you would be able to find this example under the example design library.
Chee Pin
Tnx cpchan!
Which is the older version of quartus/dspbuilder that contains this example?
Is the Quartus 18.1 Standard sufficient?
