15 years agoDC offset removal using FPGA?
I am new to interface FPGAs with DSP concepts. I have ADCs and then i have deserializers after them to parallelize the data. So should i apply the DC removal after the deserializer or before it? ...
15 years ago --- Quote Start --- why are IIR recommended, can we use FIR too? --- Quote End --- Either will work. Ultimately it comes down to filter performance versus FPGA resources; IIRs can be more efficient, but they can have issues with stability and phase non-linearity, however, these issues can be overcome. --- Quote Start --- I would be thankful for any help in form of any manuals or tutorials for implementation of these concepts in equivalent verilog (FPGA) domain? --- Quote End --- Here's a tutorial you can look at, with associated VHDL http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-100paper_hawkins.pdf (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/esc-100paper_hawkins.pdf) http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-100slides_hawkins.pdf (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/esc-100slides_hawkins.pdf) http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-100slides_hawkins.zip (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/esc-100slides_hawkins.zip) http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc2011_fpga_dsp_code.zip (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/esc2011_fpga_dsp_code.zip) Cheers, Dave
