Omerkv
2 years agoDC couple connectivity of LVDS protocol between 1.8V to 2.5V
Hi I would like to consult regarding the following issue: Can LVDS protocol can work on a DC couple connectivity between two FPGA's where one FPGA the LVDS pins are connected to 1.8V IO standard /v...
AqidAyman_Altera
2 years agoHi Omer,
Yes, it is supported.
As mentioned, VCCIO is not related to the combability between two LVDS interface. As long as the required voltage (Vid,Vicm,Vod,Vocm) for both interface is met, then it can work.
You can refer to below link for the KDB article on this:
Aqid
