18 years agoData type used in VHDL
Hi, I am newbie to VHDL design. I came across a question of using VHDL. I'd like to output a 17 bit data through one port (one pin in an Altera chip) to my DSP on the the same circuit bo...
18 years agoHi, Ben,
Thank you for your reply! Can I set each bit of the data as STD_LOGIC as well? Thanks, again! --- Quote Start --- You need to serialise the 17 data bits and use a std_logic type. When using a std_logic_vector type as an ouput each bit will tie up with one pin on your device. --- Quote End ---
