8 years agoData Transfer from FPGA-to-HPS
Hi, I am very new to the Altera FPGA suite (and FPGAs in general), and was looking to get some advice on how to transfer data from the FPGA to the HPS. I've done fair amount of research, but I ...
8 years ago --- Quote Start --- You can adjust the width of the bridge through its parameters. Looks like it won't go higher than 4096 though (and I'm not sure if it would even work if you tried to set it wider than the physical channel). It's really just an adapter to let you deal with the Avalon-MM protocol instead of the considerably more complex AXI protocol. (You could in principle just export hps.f2h_axi_slave and write into that.) So, yes, you write X bits at a time, advance the pointer and repeat. Why would you even want to write 37 kilobit at once, anyway? That means 37000 physical wires on the FPGA, all feeding into some IP component that tries to squeeze all that data through a 128-wire bus. You can probably figure out a way to do that, but I can't see it being very efficient. On the FPGA side, most of the data should be stored in M10Ks, which are relatively "deep" but "narrow" (each M10K can store 256 32-bit words, and produce at most 2 of them per clock.) That works well if you want to pull them out one by one and send them on their way. If you want to access all your data at once, the compiler can't use M10Ks, it has to use regular registers, so your logic utilization goes through the roof. Your chip only has 60K registers across its entire surface. --- Quote End --- Eugene, or anyone else that happens to be looking at this. I've hit a wall was wondering if you could offer some advice. Pretty much I have it set up I think the right way where for now the FPGA should be writing a 128 bit value to an address in memory, and I am trying to read it with the HPS but I am having 0 luck. Here is my QSYS setup: https://alteraforum.com/forum/attachment.php?attachmentid=15591&stc=1 I have also attached my top level code for the verilog modules: https://alteraforum.com/forum/attachment.php?attachmentid=15592&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=15593&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=15594&stc=1 . In this case I am just trying to write the debug value of 128'b1. My C Code is taken from: https://digibird1.wordpress.com/playing-with-the-cyclone-v-soc-system-de0-nano-soc-kitatlas-soc/ . I use his code for the SGDMA to try to read from 0x32000000. However I haven't had any luck. Any advice?
