13 years agoData synchronization issue
Hi, I am facing an issue while synchronizing data between two clock domains. clka is at 200Mhz, coming in to the FPGA (phase not known) clkb is at 200Mhz 180 Phase shifted (generated fro...
13 years agoThanks for the reply rbugalho... But I don't understand what gets wrong if I used the dcfifo in this case...
Also I used the signaltap with reference clock set at clka... I saw that the counter is perfectly at clkb (for example i generated 15 continues valids on clkb domain after certain period) but on the other side i.e. at clka domain I see sometimes 15 and sometime 14 and sometime 16 valids.... I also counted the valids using a counter on clka domain... In other words I am pretty sure that logic is correct but I am not sure about the synchronization or clock jitter... I also checked that there is no negative slack between clock domains. Please help... I am running out of time
