Data arrival Path in timing analyser
Hi Mingqiang,
Can you try to simulate the design and see if the signals give expected result?
KhaiY
- cosx6 years ago
Hi KhaiY,
Continuing from the gate-level simulation using Modelsim.
All ouptuts of the adders are correct as expected.
However, I still doubt whether gate-level simulation gives us correct functions in the real chip, though it is reliable to some extent.
I would use oscilloscope to do actual tests to find out what exactly has happened!
Thank you!
Mingqiang
- cosx6 years ago
Hi KhaiY,
Thank you for your method.
I guess the simulation you refer to is the gate-level simulation.
I had done RTL-level one before and the output sof the adder were correct.
I tried gate level simulation, but it did not give me any timing information about the cascaded length delay. I thus abandoned it.
I would double check the functionality simulation at this level latter. Nevertheless, since I will get an oscilloscope today, it is worth measuring the outputs to see the exact waveforms.
Thank you still for your concern! I will update what I found with you!
Best Wishes,
Mingqiang
