User1584607963412451
6 years agoDamaged/Defective part to send for FA
Hi Team
We have received RMA for part#A1822-5790 with MPN: 10M08DAU324I7G. Currently we would like to seek for your help to send this damaged/defective FPGA to Intel for failure analysis. We alread...
Deshi_Intel
6 years agoHi CheeHeng Ng,
Thanks for performing X-ray test.
- Can you elaborate more on what's the failure symptom ? Kindly fill up attached "failure description form" template to help me understand your issue better.
- Also may I know what else of debugging that Jabil has performed to isolate this is potential defective FPGA issue ?
- Like have you perform unit swap test ? replace another good unit on failure board then test passed ? solder bad unit to another board and test fail as failure symptom follow defective unit.
dlim
6 years agoHi dlim
Sorry for our late reply. Please find attached the failure description form for your checking. Thank you
CheeHeng Ng
- Deshi_Intel6 years ago
Thanks for clarifying the failure symbol.
Now I understand the failure is regarding issue in detecting FPGA itself.
- I presume this is abnormal case with low failure rate and not related to potential manufacturing process itself, right ?
- Max 10 FPGA contains internal flash inside the device itself. Sometime the FPGA detection issue is due to user program corrupted image to the flash causing whole Max10 can't be detected anymore. Has Jabil work with your designer team to delete the flash content to debug this issue ?
On a side note, pls help to file up attached DPR form to help me understand the issue background and debug that Jabil has done so far (only fill up second FPGA-CPLD sheet).
- So take note that you confused on FPGA MPN, Lot number, Date code and trace code marking info earlier. You can refer to "Altera" pic diagram that explained on how to read the device marking info accordingly
dlim
- User15846079634124516 years ago
Hi Deshi
Please note our reply as below:
- I presume this is abnormal case with low failure rate and not related to potential manufacturing process itself, right ? --Yes, as there is no any abnormality in test and visual inspection.
- Max 10 FPGA contains internal flash inside the device itself. Sometime the FPGA detection issue is due to user program corrupted image to the flash causing whole Max10 can't be detected anymore. Has Jabil work with your designer team to delete the flash content to debug this issue? --Waiting for customer feedback.
We shall get back to you on remaining query and DPR form. Please bear with us for the time being.
