17 years agoDamaged Cyclone 3 Chips
I am using a Cyclone 3 EP3C10E144C7N chip that is mounted on a third party board (the schematics of the board is attached in the file DB3C10.pdf). This board's I/O pins are interfacing with the I/O p...
17 years agoThanks pletz and FvM!
Does it mean that when there is a short circuit between VCCINT and gnd, as well as between the IOBANKs and gnd, there is a very high chance that this is due to high voltage transients? For my VCCINT, the 1.2V input is actually produced by a voltage regulator. The last i checked, my voltage regulator is working as it should be. From what i heard, the output of voltage regulators should be pretty stable right? From the application notes, it is recommended that i apply a series resistor to the I/O pins to minimize voltage overshoot. But if i add a resistor for each I/O pin (which in my case runs up to something like 55pins), it'll be quite tedious. So before i embark on doing this tedious task, i'd just like to verify that there is a high possibility that my chip died really because of the absence of these series resistors.
