10 years agocycloneVGX transreceiver compatibilityi PCML to CML
Hello to all.. I would understand if this SFP module (see image) is compatible with the transceiver CycloneVgx. In the fpga board the transreiceiver power is 2.5V. The sfp modu...
10 years agoYes, you can.
I suggest you use the "GIGE-2.50Gbps" template (from the library - double click on it) and work backwards from there, changing any settings you need to. Change the "Parameter validation rules" to "Custom" and ensure the 8b/10b encoder/decoder is selected on the "PCS Options" tab. Cheers, Alex
