10 years agocycloneVGX transreceiver compatibilityi PCML to CML
Hello to all.. I would understand if this SFP module (see image) is compatible with the transceiver CycloneVgx. In the fpga board the transreiceiver power is 2.5V. The sfp modu...
10 years agoHi a_x_h_75!
I need use a simple protocol 8b/10b in my application (2.5 Gbps DATA and then 3.125Gbps bit stream). Can i use a custom phy megafunction? is it configurable for this pourpose?
