10 years agocycloneVGX transreceiver compatibilityi PCML to CML
Hello to all.. I would understand if this SFP module (see image) is compatible with the transceiver CycloneVgx. In the fpga board the transreiceiver power is 2.5V. The sfp modu...
10 years agoPCML is Altera's "Pseudo Current Mode Logic". The FPGA's I/O doesn't have a true CML structure - it can't, the I/O is flexible to accommodate a variety of I/O standards. So, Altera have simply named it PCML to clearly show that it isn't true CML. However, it can be used to connect directly** to an SFP module.
**Thanks to AC coupling in the serial links on the SFP module. Have a look through App Note 518 - "sgmii interface implementation using soft cdr mode of altera fpgas (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an518.pdf)". This discusses interfacing SFP modules to FPGAs. You may want to refer to the following thread too: (http://www.alteraforum.com/forum/showthread.php?t=30105)http://www.alteraforum.com/forum/showthread.php?t=30105 Cheers, Alex
