10 years agocycloneVGX transreceiver compatibilityi PCML to CML
Hello to all.. I would understand if this SFP module (see image) is compatible with the transceiver CycloneVgx. In the fpga board the transreiceiver power is 2.5V. The sfp modu...
10 years agoHi Alex!
I agree with you. But my problem is with the electric level compatibility, CML of the SFP module, and the PCML of the fpga --- Quote Start --- The SFP module is not tied to any particular protocol. It can carry Gig Ethernet but it doesn't have to. So, you should have no problem sending 8b/10b data, at 3.125Gbps, from a Cyclone V GX device (transceiver speed grade 6). Cheers, Alex --- Quote End ---
