10 years agocycloneVGX transreceiver compatibilityi PCML to CML
Hello to all.. I would understand if this SFP module (see image) is compatible with the transceiver CycloneVgx. In the fpga board the transreiceiver power is 2.5V. The sfp modu...
10 years agoI must use the sfp module at 3.125 Gbps (it support up 4.25Gbps).
In my application i not use the gIgabit ethernet standard. I need to encode data with 8b/10b and then send it to sfp module. --- Quote Start --- Does the SFP module you refer to comply with the inf-8074i specification (ftp://ftp.seagate.com/sff/inf-8074.pdf)? I suspect it does. Refer to Altera's "serial gigabit media independent interface (https://www.altera.com/solutions/technology/transceiver/protocols/pro-sgmii.html)" page. This discusses connecting SFP modules to Altera FPGAs, including Cyclone V GX. Cheers, Alex --- Quote End ---
