10 years ago(CycloneV) Writing 128bits to FPGA at once using linux kernel module
Hi, I'm trying to write a kernel module that writes 128bits of data to the FPGA using the HPS-to-FPGA bridge. The bridge width is configured as 128 Bits in Qsys and I'm using memcpy_toio() to w...
10 years agoA colleague of mine was able write 64bits at once using the HWLib and the Socal.h library from userspace, but I those seem to be designed for userspace only. I'll try to manipulate the fn_mod registers, though from the documentation I gathered that the merging should be enabled by default.
