ENava
2 years agoCycloneIV-E external ADC parallel interface timings
Hi all. I'm interfacing a CycloneIV-E to a AD9266 ADC and I'm struggling trying to close timings. FPGA design has one 100MHz pll clock; the adc is clocked with a divide-by-two register (=50MHz); da...
SyafieqS
2 years agoFrom the timing report, seem this issue probably related to CDC. Have you tried to constraint the CDC between the 2 different clocks?
This might be the reason why you are having a large skew. Multicycle path or synchronizer is the way to handle this.
