11 years agoCycloneII "freezes"
I use a CycloneII (EP2C5T144) as a global control of a high power electronics board, designed a few years ago.
Now there is notest on some boards that the FPGA "freezes" during operation. After a power cycle it works Ok for a time until it again freezes. * Investigations done: 1) When "freezed": All power rails OK. All user IO seems to be at Tri-State/High-Z: IO-levels are in accordiance with the external Pull-Up or Pull-Down Ressistors. Measured some extra signals: ConfigDone: High-3V3 nConfig: High-3V3 nCE: Low-0V (Pull Down via 10K) nStat: High-3V3 Clk: OK, 32Mc, 3V3 MSEL1,2: OK, 2b'10: Fast AS-Mode Signals to EPSC1: all signals High-3V (3V ok??) JTAG: FPGA reconized via JTAG (ref. "Auto Detect") 2) Try to "unfreeze": Recycle the power of the total board: OK. FPGA running. Loading the SOF-file via JTAG: no errors, still "freezes". Pulling nConfig down: still "freezes". 3) At the molent the FPGA "Freezes": Checked the voltage rails: OK, no dips, no overshoot. * Extra Info: EP2C5 is configures in ASmode with an EPCS1. It's a power electronics board: so there can be expect some noise. If the FPGA freeses it is always when the board is at max load. No use of any tri-state IO on the logic design. No use of the nDEV_CLR and/or DEV_OE pins. *Some tips? Does someone an idea why the FPGA-IO goes to global Tri-State/High-Z? Does someone hase some ideas about extra checks, measurements? Thanks, Kind Regards, SDPRNo RepliesBe the first to reply
