17 years agoCyclone3 Power Up level doesn't work
A design with an EP3C40F324I7 has the pin U18 as an registered output. This pin is used to control another dcdc's nSHDN (Shutdown negativ logic) The fpga is configured via epcs. this dcdc is ...
17 years agoI appologize. I initially misunderstood and thought you were trying to power-up high. Not low.
Jake --- Quote Start --- @Daixiwen @ Jake i tried different ways //verilog 1995 reg Enable_3V /* synthesis altera_attribute = "-name POWER_UP_LEVEL LOW" */; // Verilog 2001 (* altera_attribute = "-name POWER_UP_LEVEL LOW" *) reg Enable_3V; as well as reg Enable_3V = 1'b0; but none of them works. between power on and until the fpga starts to work in user mode the pin is 1 as soon as the user mode is reached, this pin goes to 0 so it seems that it is realy impossible ... i can't go to 2k pull down as this will disable the soft start function of the dcdc --- Quote End ---
