18 years agoCyclone3-Overshoot/Undershoot
Hi, After PCB Design CIII – EP3C40 based board, in the post routing SI Simulation we are getting some overshoots and undershoots in DDR Signals and LVDS (As receiver) signals. As we are using DDR1 s...
18 years agoHello FvM,
Thanks for your comments on the waveforms. Because of space constraints we had to place the termination resistors a little far away from the FPGA. The average trace length between the Termination Resistor and the FPGA pin is approx 1000 mils. I am attaching the Gerber Files in PDF format in the forum. You are kindly requested to give a look and suggest any better solution if possible for the improvement of the signals. Regards, S Sarkar
