Cyclone10LP SEU CRC error implementation
As we do not receive any response from you on the previous reply that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you,
Kshitij Goel
- UF12 years ago
K**bleep**ij,
I already clock the cyclone10lp_crcblock but the output signal regout is stucked to 0 (I check it with signaltap).
As you don't see the attachment, here is the IP instantation and the process to clock out the data :
//----- Instantiation and configuration -------------------------------------------------------
uut_cyclone10lp_crcblock : cyclone10lp_crcblock
generic map
oscillator_divider => 8 ,
lpm_type => "cyclone10lp_crcblock")
Port map
clk => s_clk_crcblock ,
shiftnld => s_shiftnld ,
ldsrc => s_ldsrc ,
crcerror => s_crcerror ,
regout => s_regout
);s_shiftnld <= '0';
s_ldsrc <= '0';s_clk_crcblock <= i_clk when s_output_crc='1' else '0';
o_regout <= s_regout;
o_error_pin <= s_crcerror;
//----- Process to output data -------------------------------------------------------
pro_get_crc32: process(i_clk)
beginif i_rst = '0' then
sv_cnt <= (others=>'0');
sv_crc32 <= (others=>'0');
s_output_crc <= '0';elsif rising_edge(i_clk) then
-- Wait 10 s @ 60MHz then output register : 600000000
if unsigned(sv_cnt) = 600000000 then
s_output_crc <= '1';
sv_cnt <= std_logic_vector(unsigned(sv_cnt) + 1);-- Stop after 32 clocks 600000032
elsif unsigned(sv_cnt) = 600000032 then
sv_cnt <= std_logic_vector(unsigned(sv_cnt) + 1);-- Stop counter 33 clocks 600000033
elsif unsigned(sv_cnt) = 600000033 then
-- Count after reset
else
end if;if s_output_crc = '1' then
sv_crc32 <= sv_crc32(sv_crc32'length-2 downto 0) & s_regout;
end if;
end if;
end process;Regards,
Gorka BIROT
2.15.0.0
