10 years agoCyclone V
Hello.
It is necessary to accept a serial code with a speed of 768 Mbps and to transform it to a parallel 8-bit code with a frequency of 96 MHz. Proceeding from an objective, what IP-core you will recommend to use? There were attempts of implementation of this project on Custom PHY Tranciever. There were following questions: 1) How there is a synchronization at reception of serial signal? (How I can organize this synchronization?) 2) When using Custom PHY Tranciever is it possible to use only levels 1.5 PCML? 3) Do you have any recommendations for realization of this problem? I use next equipment: - Cyclone V GX Starter Kit The used software: - Quartus II 13.1 (64-bit)No RepliesBe the first to reply
