11 years agocyclone V transceiver using as IO?
Hi, For extraxting data from a 576Mbps serial datastream (subLVDS) with a DDR clock of 288MHz I would like to use the transceiver inputs of the Cyclone V. Can I do this easily? Can I use the tr...
10 years agoHi,
you make me curious about the camera/image sensor you are using. Can you tell me what type of HSMC connector you use and what kind of dev. board? Best regards. --- Quote Start --- OK, that is encouraging. I'm using the HSMC interconnect at present. Engineering our own PCB should improve things. Experienced a lot of grief with using Quartus 13.1. had to upgrade to 15.1 to fix the ALTLVDS__RX to fix issues with the internal PLL. Thanks again. Regards Phil --- Quote End ---
