11 years agocyclone V transceiver using as IO?
Hi, For extraxting data from a 576Mbps serial datastream (subLVDS) with a DDR clock of 288MHz I would like to use the transceiver inputs of the Cyclone V. Can I do this easily? Can I use the tr...
10 years agoOK, that is encouraging. I'm using the HSMC interconnect at present. Engineering our own PCB should improve things. Experienced a lot of grief with using Quartus 13.1. had to upgrade to 15.1 to fix the ALTLVDS__RX to fix issues with the internal PLL.
Thanks again. Regards Phil
