11 years agocyclone V transceiver using as IO?
Hi, For extraxting data from a 576Mbps serial datastream (subLVDS) with a DDR clock of 288MHz I would like to use the transceiver inputs of the Cyclone V. Can I do this easily? Can I use the tr...
11 years agoHi,
The Cyclone V transceiver's minimum supported data rate is 614Mbps which is higher than your 576Mbps requirement. You might want to consider oversampling to meet the data rate specification of the transceiver.
