10 years agoCyclone V spi memory access
Hi, I wanted to know if the spi flash memory which is present inside the cyclone v can be accessed directly by an external flash. If so can anyone guide me through to how to do it as I am not a...
10 years ago --- Quote Start --- There is no SPI flash memory that is internal to a Cyclone V device. Are you referring to the SPI master / slave controllers in the HPS Cyclone V SE devices? What specific Cyclone V device are you working with? --- Quote End --- I am referring to the quad SPI flash which is external to the Cyclone V. I am using the device CycloneV : 5CEFA4U19C7 The flash signals are tied to the FPGA and I am not able to use those pins as a normal IO. I want a method or a way to access those pins directly.
