11 years agoCyclone V SOC GPIO test by register access
Hello together,
for a simple hardware test I want to set/clear a HPS GPIO pin by writing values into the corresponding registers. I have activated GPIO00 in QSYS and in Quartus connected with a top level signal. The fitter assigns the correct pin automatically (Pin E4 in a Cyclone V SE with 672 pins). Linux is running after startup and via console I made the following register settings: (0xffd08400) = 0x00000000 (EMACIO0, multiplexer setting for GPIO/LoanIO) (0xffd085d4) = 0x00000001 (GPLMUX0, multiplexer setting for GPIO0) (0xff708004) = 0x00000001 (GPIO0 data direction as output) Now I expected to set / clear the pin via register 0xff708000 / bit 0. But the pin remains in high ohmic state. What did I forget to do? Quartus Version 14.0 Device 5CSEBA5U23I7N
