10 years agoCyclone V: Set LVDS output buffer delay
Hello everyone,
I have an application where I'd like to compensate board trace length differences using (fixed) output delays. The outputs are driven by the dedicated SERDES hardware with an LVDS I/O standard. I have set the assignments like this:set_instance_assignment -name OUTPUT_BUFFER_DELAY 119 -to IO_B4A_B52_AG14_P IO_B4A_B52_AG14_P is the name of the positive LVDS output pin. This looks fine, but the fitter complains: Error (169226): I/O standard LVDS on pin IO_B4A_B52_AG14_P cannot have Output Buffer Delay logic option setting 119 Is it impossible to set output delays for LVDS buffers? Or do I need to assign them in some different way? Thank you! Best regards, Philipp2 Replies
Hi Alex,
thanks for your reply! Will need to look for another way of improving my signal integrity then... Best regards, Philipp - Altera_Forum
Your assignment is correct. However, LVDS is not a supported I/O standard when using the programmable output delay.
Refer to the 'programmable ioe features in cyclone v devices' section and table 5-24 in the 'cyclone v device handbook (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/cyclone-v/cv_5v2.pdf)'. Cheers, Alex
