12 years agoCyclone V SerialLite-II
Hello all, I am trying to impement SerialLite-II on a Cyclone V. I have my design to the point where I can simulate it successfully, but synthesis fails with the following error: warning: ...
12 years ago --- Quote Start --- BTW, proper configuration of the transceivers is key, and generally, you need to avoid using the middle of transceiver triplets if you want full-duplex. But this depends heavily on your particular design. It took a while of digging through documentation for find valid transceiver configurations. --- Quote End --- 2 Questions: 1. Why to avoid using the middle of transceiver triplets if I want full-duplex? 2. The controller in your design is necessary? what is part if I don't want to reconfig anything?
