12 years agoCyclone V Local or Remote Configuration
Hii, I don't understand why the LOCAL Configuration Mode is not possible with a Cyclone V Device attached to an EPCQ Flash. I want to have the possibility to do a remote configuration of the flash u...
12 years agoI'm not sure your question is clear...
--- Quote Start --- LOCAL Configuration Mode is not possible with a Cyclone V Device attached to an EPCQ Flash --- Quote End --- You can configure a Cyclone V device from an EPCQ FLASH device connected to it. Is that what you mean by 'local'? You also mention reprogramming the FLASH upon power up, remotely, is that right? Providing the FPGA is configured before you do so, and you have IP in there to support programming of the FLASH, that should be possible. Regards, Alex
