11 years agoCyclone V HS serial interface
Hi. I need an advice in high speed serial interface implementation for Cyclone V GX. I want connect my boards in next sequence: tx0 - > rx1_tx1 -> rx2_tx2 -> ...... -> rxn. Receiver_1 is connect...
11 years ago --- Quote Start --- Hi andrei_hres, The additional channel used by the XAUI core is for the TX PLL. For your information, the transceiver channels required a TX PLL to generate clocks for the transmitter. --- Quote End --- Hi nic_@ Does this mean that in chip with 9 transceivers I cannot implement XAUI and Custom PHY with 4 lines? For this purpose I need use chip with 12 transceivers? I try different settings for Custom PHY core and find that in my chip I can implement XAUI + 3 lines Custom PHY. Is there any configuration for transceivers when I can implement XAUI + 4 lines Custom PHY in chip with 9 transceivers?
