11 years agoCyclone V HS serial interface
Hi. I need an advice in high speed serial interface implementation for Cyclone V GX. I want connect my boards in next sequence: tx0 - > rx1_tx1 -> rx2_tx2 -> ...... -> rxn. Receiver_1 is connect...
11 years ago --- Quote Start --- Ideally there should not be issue with the board connection as long as the SI is meeting all the required specs. You should try check functional simulation before implementing. --- Quote End --- Thank for your reply. I will try to do this. I have one more question. I implement XAUI core (or Custom PHY core with 4 lines). It takes 4 transceivers channels plus 1 channel (clock select MUX + channel PLL + clock divider)? Why does design with four lines occupy 5 channels? What can I do to set this core for using four channels?
