11 years agocyclone V GX encryption(5CGXFC5C6F27C7N)
How to program non-volatile key into device? How to encrypt configuration file? thanks!!!
11 years agoIf you have subscription license then you should be able to generate encrypt configuration file. You need to use Ethernet Blaster cable to program the non-volatile key. You can refer to the details from the AN556 here:
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an556.pdf
