Cyclone V GX C5 CRC_ERROR pin
- 2 years ago
Thanks for the update. Just to let you know, this case was set to close as we did not received any update from you after my final response.
For pin assignment for CRC_ERROR and V20, you may refer to pinout file and mapped it accordingly. Do not need to assign using pin planner. Please ensure follow the pinout file and guidelines.
Aiman
Per the device connection guidelines below,
"When you use the dedicated CRC_ERROR pin configured as an open-drain output, connect this pin through an external 10-kΩ pull-up resistor to VCCPGM. When you do not use the dedicated CRC_ERROR pin configured as an open-drain output and when this pin is not used as an I/O pin, connect this pin as defined in the Quartus Prime software. The I/O buffer type is reported in the fitter report."
I don't understand what this has to do with Pin V20?
Aiman
