12 years agocyclone v encrypt
hello, help please. I have successed in encrypting Cyclone V FPGA configuration data with volatile key which is stored in FPGA internal ram. However, a battery(volatile key should use it) on ...
12 years ago --- Quote Start --- So, we want to know whether only ethernet blaster can be used in non-volatile key writing or both ethernet and usb blaster can be. and if battery is used(volatile key used), how long the battery can maintain. thanks very much! :) --- Quote End --- I've been told that the USB Blaster II will also be able to write the non-volatile key, but those are not available yet. The only present solution I know of to write the non-volatile key is with the Ethernet blaster.
