Cyclone V E Development kit sdram parameters
I have a Cyclone V E Development kit. I want to set up Sdram for heavy nios II code.
What is the parameters of sdram controller IP for Cyclone V E?
Is there any sdram example for this kit?
- BoonT_Intel
- BoonT_Intel
Hi Sir, you may install the cyclone V E dev kit installation that can get from this link - https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/kit-cyclone-v-e.html
There should be the DDR3 example or board test system design that you can open the IP GUI to check the parameters.
- NurAida_A_Intel
Hi Sir,
Welcome to Intel Community.
As per my understanding, you are looking for design guideline or example design of the SDRAM controller. Please let me know if I understand this correctly.
If yes, you may refer to this EMIF handbook for the design guideline : https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/external-memory/emi_plan.pdf
Hope this helps.
Aida
